More testing of lenses today. Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode. Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8 so probably correctable or slight crop to 80-90MP). Perfect in 35mm mode. Zeiss C/Y 80-200 f/4 (manual focus/aperture) - slight vignette but better than both the above. Zeiss 28-85 f/3.3 (c/y manual focus/aperture) - not as bad as the Nikon 70-200 f/2.8 but still dreadful. Sigma 24mm f/2.8 superwide - heavy vignette as above. -
