After easing myself into the Fuji world...I finally shot a wedding last week completely with my Fuji setup.  I still brought one of my Nikon bodies just incase...but the fujis held up great throughout the day!  My setup was
2x X-T1
Rokinon 12mm
23mm 1.4
35mm 1.4
56mm 1.2
90mm 2.0
The majority of the day was shot with the 23mm on one body and the 56mm on the other.  For the ceremony I would occasionally switch from the 56 to the 90 and for the open dancing I just have the 12mm on.  I'm getting used to the 23mm/56mm focal lengths.  Over the last couple of years I've been using full frame DSLRs with a 50mm being my main lens.  Not sure why, but the 23/56 combo feels great for me now where the 35/85 combo on a Full frame didn't.
