I want to use my T2 coupled to a telescope. Setting B exposure time just gives me a 1s exposure. I hold the shutter down and get 1 second, then the shutter closes despite the shutter still being pressed. I want to do as the manual suggests it should work and have the shutter open all the time the shutter is pressed.
Any thoughts are welcomed.
Looks like I’ve solved my own problem. I had set the shutter type to electronic (ES) but it seems that it won’t then do ‘bulb’. Went back to mechanical and it seems to work fine. I was trying to eliminate any disturbance of the camera to avoid any vibration while taking the image.
For some reason, Fujifilm limits the electronic shutter to 1 second exposures in bulb mode. If you want longer electronic shutter exposures, switch the shutter speed to t mode and set longer times.
p.s. Welcome to the forum.
Edited by jerryy
    • Example: I am using a custom recipe, and I then use the film simulation dial to select a simulation. Are values from the custom recipe carried over, such as highlights, shadow, and white balance etc.? After studying the articles in Fuji X Weekly, this appears to be the case If you set a recipe on one of the C slots its settings will be applied to all the film simulations on the dial. The workaround is to use your 'standard' recipe at C1.   Please clarify this for me . I would have thought the film simulation dial would have no input from other camera settings.   Thank you - Very Confuded!
    • Is this on the X-T30 II? Sounds like you have HDR selected in the shooting menu. The other alternative when you see the "storing" message is that the Clarity setting is non-zero but that doesn't cause multiple clicks.
    • My XS10 came with a Capture One license but my PC at the time would barely run it so I stuck with my ancient version of Picasa.  Bought a new PC and my old Capture One has been deprecated and fuji site only talks about a 3 month trial.  Is there a work around or should I be looking for something else?
    • On aperture priority and single shot, camera clicks twice after one shot and then takes several seconds showing "storing" message.  This is a new camera and did not do this at first.  Does not do this on auto.
    • I have the Fuji 80 mm macro and really like it. It's very sharp and I use it for macro but also for general photography. If you find yourself zoomed to 55, this may land in the right spot. Also, this lens is very good with magnification distortion (pincushion or barrel), which is probably important if you're doing product photography and the product has straight lines. It is autofocus. I hear you don't prioritize that, but there's something else you gain when you have autofocus. You can combine multiple photos taken at slightly different focus distances, using stacking software, and autofocus lets the camera automate the process of taking all these, using focus bracketing. It even calculates how much the focus should change between these exposures. This lens, new, is above your stated budget. Maybe you can find it used? In any case, options are always nice to have, and others may like this option too. So, just a thought. One more thing: I've never used the Laowa macro you mention, but I do have their circular fisheye. I love circular fisheyes, and also have two other brands, and comparing them I find the Laowa is considerably better than the other two. That's a vote for Laowa.
