I purchase an Fuji X-T2 which I've been using to shoot soccer with a zoom XF 50-140/2,8
It's a big step up from the X-T1 in AF-C capability.
I've got the AF-C setting set to second custom preset „Ignore obstacles&continue to track subject“, and it works fine. I have done ca. 600 photos and only 4 was total out of focus. The most of photos is razor sharp. Some photos is little bit soft, but without problem - it can be easy solved by post proces.
Other setting:
shutter 1/1000, aperture f4, ISO AUTO, phase detect area 3x3 (zone focusing), CH 5 shots/minute, boost ON, grip XT2-VPB. !! lens OIS was OFF !! becausse panning.
Conclusion:
I´m very satified with the AF-C and keeper rate.
Any other settings I should be playing with?
Edited by hildasea
