Recently I noticed a few issues with my X-T3.
All of the sudden and for no apparent reason, entering the firmware upgrade menu no longer works like it used to, by simply holding down DISP/BACK and turning the camera ON. Now I have to hold  down DISP/BACK, switch the camera ON AND fully press the shutter a few times.
Also I recently noticed the camera became REALLY SLOW in waking from sleep. It's usual behaviour is that it would wake from sleep in just a second or two when half-pressing the shutter button. Now it takes several (closer to 10-15) and several full presses on the shutter buton for it to wake from sleep.
Also, the camera won't power on by simply simply ficking the ON/OFF switch. I have to press the shutter button a few times in order for it to actually turn on.
Any ideas?
Edited by radumitrescu
  • radumitrescu changed the title to Several issues with my camera as of late
    • I am very tired of Fuji as a whole... They automatically deny responsibility on issues, quote crazy high repair prices and timeframes and when I accepted a (refurbished" replacement 100-400 instead of a repair because to would be cheaper and faster it developed the exact problem a couple years later, My XT4 is absolutely unreliable because of the turn on turn off issue that has persisted through numerous attempts to fix it and my 10 to 24 would not focus at infinity and struggled to focus at all, and I went through two of them because of focus issues. My sigma is much better.
