Tenerife night sky
texture
Hi,
I was recently on a short trip to tenerife for my first serious milky way shots.
The following photos were taken with my X-T1 and the 14mm and 35mm lenses.
Additional information about used gear and my workflow can be found on flickr in the image description.
More shots can be found in this flickr set: https://www.flickr.com/photos/28058855@N02/albums/72157669244098234
Hi,
Looks awesome.
I am going there next Tuesday for 2 weeks and plan to do the same. Will be very happy to reach the quality of those.
I don't think I'll have time to do panorama since I'll be with my family.
I plan to use the Samyang 12mm f/2 and do as as many as I can and stack them.
    • FYI Update - I just learned that the Zoom F6 & F3 recorder/mixers also synch to the UltraSynch Blue over bluetooth. I am planning to record 32bit float on the F6 and it will have frame accurate matching time-code with my two-XH2S' and one XH2.
