Hi All!
I am an owner of a X-H2 and some xf lenses an in passion with photography since many years.
I tried out to go beyond 1/8000s in all configuration but it does not work. It ends at 1/8000s and the ES doesn‘t activate and jumps beyond.
If I‘m using the ES online, it works like described.
Using the X-T3 for example with same settings it works only with setting „T“ on the Shutter Speed Dail.
OK, most problems occoure behind the camera body 🤣, so what am I doing wrong?
Thnx!!!!🙏
Regards,
Sascha
So to be clear - if you set the camera on shutter priority and shutter type = "M" the highest speed achievable by rotating the command dial will be 1/8000.
If you change shutter type to "E" (without changing anything else) the highest speed goes over 1/8000
if you change shutter type to "M+E" the shutter speed limit goes back to 1/8000? (Again without changing anything else?)
2 hours ago, Sascha said:
Yes you summed up correctly.
Hmm - I have the X-H2S rather than X-H2 but I ran that exact same test and shutter type M+E doesn't work like that - it allows the same extended shutter speeds as the electronic shutter.
