Hi all,
I shot a clip on XH2s - the full clip is playable on the camera, but when i attempt to download through image capture onto my MacBook Pro - a portion of the clip is not playable (it appears greyed out)
if you have any thoughts on this issue I am experiencing, I can share more details regarding settings.
Any help on this issue would be much appreciated!
