  • 10 months later...
On 9/12/2023 at 7:33 PM, Clarissa said:
I am in the same case, I couldn’t find one, cheap and useful. I want to taste the x100s sea frogs housing in my Fuji but right now I couldn’t do it, if you find one that match perfect it would be nice!
Did it fit in the end?
