Morning. I’m suddenly having issues with my landscape JPEG images not being sharp. The JPEG image size also appears to be half what they usually are. Any idea why? Wondering if I have inadvertently changed a setting.
I do have the RAW files too but just use the JPEG’s for social media.
Thanks
