No because I shoot a lot of adventure and sports, when I use AFC I need the ability to follow subjects and refocus. Interestingly, when I switch the focus to Manual I can use the back button focus. I'm not sure if that's normal but it's working 🤷🏻‍♂️
  • 2 years later...
