city of Bergamo, X-T1 + 16-55, Italy
Drinks are pleasant objects to photograph. They do not run away, and while taking a picture, you enjoy the drink too.
You allow me to criticize your picture?
Focus aside and DOF too short. And the drink would look nicer with a clean or interesting background.
Framing ... hm ... composition, well ...
Not sure whether an ultra-wide fits well for a drink. :-)
When i take a picture of a drink it's kind of a "finger excercise".
If it just was a snapshot which you wanted to share, forget about my critics :-)
And don't take it too serious; i'm just sharing thougts.
