Hi everyone, quick Q for the seasoned wedding photography pros:
What type of shoes do you recommend for photographing a sandy beach wedding? I don't think going barefoot will work because when I actually need shoes, like when making trips to the car etc, I don't want to be carrying shoes/sandals with me and then having to put them on and take them off. Also, flip-flops might kick up too much sand and I'd hate to spray the guests as I walk by. Any ideas or any other tips in general?
Thanks for your input!
