Had a great walkabout in London a few weeks back taking in the market on Brick Lane and a walk through the City of London to end at Madison's overlooking St Pauls Cathedral...
Images taken with Fuji x100s
Great location and nice spot to walk around.  A few thoughts on each:
1) The lighting in the first image is really nice, with the shadow on the wall either side of the subject.  It might make a nice mono actually.
2) The focus on the second shot appears a little off/not enough DoF.  Also the vignette appears weird, have you done any work in post? I find the couple in the background really distracting.
3) Third shot appears slightly under exposed and the head in the background isn distracting.
Shot number one is definitely the winner for me!
