Hi
I want to assign to c1,c2,c3 etc the iso
I can do that but it seems that i have to assign a shutter speed to each one of the customs, so each time that i am switching to a new custom mode i am getting a new shutter speed
Any ideas how to assign the isos and keep my current shutter speed?
