Freaking New Guy that is. I'm currently shooting Nikon camera's, a D500, and a D5600.
I am on notification lists at several online camera retailers for a Fujifilm X100V. It appears these are fast approaching Unicorn status.
Any truth to the rumor that these cameras are readily available in Europe?
In my search for this camera, I've been smitten with Fujifilm products in general. I so want a X100V as a compact camera to carry on vacations, even probably more often just when out and about.
