Thanks Warwick,
The 18mm is part of my Holy Trinity (18mm f2 / 35mm f1.4 / 56mm f1.2APD) I also have the superb 55-200 for special events.
I am loving the X-Pro2 and find it a huge step up in performance from the X-Pro1 (which I intend to keep).
I am sure you will get a great deal of satisfaction from the combo as the 18mm is instant on the new camera.
Enjoy!
