I have just started using a new 35 1:2 on the X-Pro 2 with the OVF and the Corrected AF Frame activated. I noticed that the short distance frame with this lens is placed farther from the long distance frame compared with the 35 1:1.4 and it is also smaller. According to the camera Owners Manual the short distance frame is supposed  to be placed in a position corresponding to approx 50 cm focussing distance but I suspect that with this lens it is placed at the minimum focussing distance (35 cm) which makes a huge difference. Has anybody else observed the same?
Thanks
Me and this guy on youtube (Rediscover Film) noticed it also.  And, this was on the old X-Pro1 when we noticed it.. it appears to be the same case on the x-pro2, huh?
He made a video about it, see link attached here.
Also, I've asked Fuji Guys, they have no answers.
You would think that both 35mm f1.4 & f2 would have the same representation of the corrected AF frame, but they are significantly different.  Anyways.. just have to get use to the difference.
Edited by Wing0949
