Hey guys!
Can anyone help me finding the Bulb Mode on the X S10?
I already read the menu and I've been trying everything. The manual just says "using the rear command dial, choose a shutter speed of [BULB]".
But the only thing that the rear command dial does is to change the shutter speed. It doesn't show any Bulb option.
Thanks
11 hours ago, Olaf W. said:
Welcome to our forum. Perhaps you are using the electronic shutter and the bulb mode only works only with the mechanical shutter. But I must admit that I'm only guessing since I don't use bulb very often.
Thank you for your reply! Unfortunately that didn't work. :(
  • 7 months later...
  • 7 months later...
  • 1 year later...
