Hi, I had purchased my x100t in 2016 and have used it moderately.
i took out the camera after 1-2 months, which was kept safely without battery and card since I was travelling and didn't need it
I find when I select f8 on the aperture ring, the value on lcd in f2.8 and if I selected f16 it is showing f5.6. Basically the wrong values
please suggest how I can fix this at home
thanks
Sid
Mumbai, india
Set the lens to f2, insert a fully charged battery and restore to factory settings. Make sure that you have the latest camera firmware  installed (v1.11). If that doesn't help, your camera needs to be brought in for repair.
