So I am trying to order a bag and tripod today. It's between the 3 legged think Rick vs mefoto road trip aluminum and bag that fits them inside. What do you guys think ? What do you use? How's the stability for long exposure shots? I'd really like the tripod to fit in a bag for portability . I know several bags fit them, any suggestions? Anyone used the amazon basics case?
Guest Ridgeback
I have the MeFoto am as pleased as pie with it.
It has been traveling and hiking with me, both in its own bag and attached to a ThinkTank backpack. I just love it and give it a big thumbs-up!
