Here is the proposition of upgrading the X-S10 firmware
Revised specification from Ver.2.10/2.11 to Ver.2.20
The following specification has been revised to improve compatibility with SDXC memory card format.
The maximum number of frames that can be recorded in a single folder has been changed from 9,999 to 999.
If you are using a macOS computer to process recorded files in the SDXC memory card, make sure to follow the procedure below before upgrading the firmware.
Follow the instructions in “II-2. If using an SDXC memory card with existing files or one that has not been recently formatted:” in the article titled “Important notice for consumers processing FUJIFILM digital camera files using macOS” that was published on Feb. 2 in this web site and then format the SDXC memory card before using it.
Minor bugs have been fixed.”
Because I don’t want to limit the number of frames to 999 in a single folder, my question is what are the “minor bugs” that are fixed here? Do they make that firmware upgrade absolutely necessary?
