Hello,
Hope someone can help with a Christmas gift fuji suggestion.
My wife has owned her trusty X100S for about 7 years and still uses it almost daily.
She loves its classic looks and portability.
We run a small business and use it taking product shots.
She often complains about the X100S struggling in the slightest of low light conditions.
I know she'd like to switch to a fuji with interchangeable lenses.
So the new camera needs to be:
A Fuji
Compact
Interchangeable lenses
Preferably less than £1500
I was just looking at the X-E4 ???
Any help massively appreciated!
Tom
if the minimalist control/body style is ok then the x-e4 is a fine choice as it has the latest sensor and processor. if you don't have any XF lenses yet then an x-e4 with the kit 18-55 might be a good starting point, although in your budget the x-s10 with the 16-80 would also fit. i chose the x-s10 over the x-e4 for the larger grip and more control dials. the IBIS came as a bonus for the same money.
you really can't go wrong with any of the latest bodies in the fuji lineup and it's more important what lens you put in front of the sensor. an x-e4 + 23f2 would be the interchangeable equivalent of the x100 (bit larger and without OVF)
i also have the x100s alongside the x-s10 so if you have any specific questions i might be able to help :)
  • 4 months later...
Define "struggling": do you mean that there are problems with image quality of the pictures taken at low light or that the handling/responsiveness of the camera at those conditions is bad?
In the first case she would be better off with an older body such as the x-e2s or the x-h1 with a (more expensive) larger aperture lens, in the latter case the new body with a cheaper f2 lens would be the better option.
Edited by Florian
typos
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
