I usually shoot only having the Electronic View Finder (EVF) enabled, but it really annoys me, that I then also have to change Settings while looking into the EVF. I'd like to have a View Mode that allows me to Shoot EVF only, but opening the Settings and Quick menu on the LCD. The only possible current solution is the time consuming rotation through the different View Modes ...
