GF80 1.7 wont allow manual set of Aperture for 1.7
Help needed. I am not sure why this is happening but I cant seem to set the aperture to 1.7 from the dial on the lens. It would always display as 2.5 on the camera. It works when i have it set to 2.8 or 2 but whenever i set it to 1.7 it just display as 2.5.
I am using it with a GFX 50R.
I tried it in all modes. M and A. I really dont know how these electronic lenses work. I am new to Fujifilm coming from all manual rangefinders and this is really frustrating me.
Thanks in advanced.
