Hi .... I'm new here.... hope somebody can help
I love my X-T3 but have a problem.
When I try to use a plug-in microphone I get 'crackling' noises in the output.
I thought that this may be the internal clock pulses coming through, but now think that it's something else .... maybe microphone incompatability .... maybe impedance problem...
Has anyone else had this ?
Does anyone please know an answer ?
Can anyone recommend a suitable microphone ?
At the moment I'm trying to use the X-T3 in one hand and a 'Zoom' camera in the other .... and no more hands to do anything else !
Any comments or advice will be really appreciated
Thanks in advance
Sasha
