Did you blur in post?  I am not criticizing.  I like the feeling it gives the photo.  Feels as if it sucks you in, but my eyes are drawn to the left and right top corners because they are so soft, then I am pulled through the image along the path and into the fog.  More so the left.
thanks.  i used nik's analog 2 and added a vignette and blur around the edges.  i try not to use it often, but it seems to work on a few images.
