Hi there!
On my X100V (Firmware V2.00) - using the OVF mainly - I noticed 2 differences between OVF vs. EVF/LCD:
  • First, when setting the front command dial to SS (Program Shift) - it doesn't shift the SS/Aperture combination in OVF. It does correctly in EVF/LCD.
  • Second, when using face recognition, it doesn't do so in OVF when AF is set to 'Zone' (maybe others too - but that's how I use it the most), but again it does correctly in EVF/LCD.
Any tips/suggestions welcome!
Many thanks,
L.
On my X100V, if I set the front dial to Program Shift, it works even in OVF mode. You need to select the full auto aperture mode (lens aperture set to A, then choose F from the front dial, move it all the way to the right).
Face Detection is not compatible with the OVF to the best of my knowledge.
Edited by flamidey
    • Which direction is the light source coming from in the dark images? For example, if it coming from behind the subject, a common occurrence known as backlighting, put some light from the front toward the subject — you can do this with a flash unit, or by using various types of colored reflectors. Or, use long exposures with various grades and types of graduated neutral density filters to bring out the dark areas without blowing out the highlights. Or try bracketing exposures. There is a technique called ETTR, expose to the right, which will bring out shadow detail but risks blowing out the brighter sections. This may help in understanding DR settings as well as Dynamic Range Priority: https://www.jmpeltier.com/fujifilm-dynamic-range-settings/ p.s. The situation you are describing has been one photographers have struggled against since cameras and photographers have been around.
    • Hi, I'm looking for some Fujifilm HDR RAF image samples from the X-T4, X-Pro3 or X100V cameras. These cameras should store 3 RAW images inside the RAF image file in HDR mode. In need it, to verify my own software, but don't find any downloadable samples on web. Can someone help? Christoph
    • I would like to get your comments on the following problem of mine: Occasionally, I do get too dark JPG pictures with X-T50 - when the scene is contrasty; I think this is the very situation. This can happen when sun shines from a blue sky or the sky is cloudy but still very bright. I find these outcomes strange, as in many other (more or less similar) situations I find that the exposure is balanced. Is there any remedy for this, as I cannot completely figure out as to why this happens. Photometry is at the most common center-weight setting. What factors/settings can affect the picture's exposure in X-T50 (in the situation I describe)? For JPGs I've set the dynamic range on (DR400 with ISO500). Can that do it?? I thought it balances contrasts... Well, I can adjust the exposure on a computer but that is extra work for holiday pictures.
    • Like Jerryy says you can scale you image down so that it can be uploaded - that way we aren't guessing. The only symbol that looks like a camera is the Continuous Mode symbol - but it normally has "L" or "H" next to it rather than a "1"
    • Welcome to the forum. I think the icon that looks like a camera you are mentioning could be the metering mode icon: https://fujifilm-dsc.com/en-int/manual/x-t4/about_this_camera/display/index.html (Number 39 or 41 depending on whether you are looking at the viewfinder screen or the lcd screen.) Have you customized any display settings? That would affect what you get to see on the displays. Akso, if you have Large Indicator Mode turned on, the M or P will not show: https://fujifilm-dsc.com/en-int/manual/x-t4/menu_setup/screen_set-up/index.html p.s. If you have an image editor, you can scale your images to a smaller size that can be uploaded.
