X-T4 aftermarket battery and charger
In addition to above suggestions: in auto-iso, set minimum shutter speed appropriate to your focal length. In low-light conditions, set aperture wide open (f1.4-f2).
Ghosts and goblins and all sorts of fey critters are stirring again. It is that time of the year. Be careful, they will soon be out and about... Boo!
First thing to try would be a factory reset. If the camera locks up before you can select it in its menus, it is still possible clear its settings-memory (cmos?) by leaving it without battery for a while. Actually don't know for how long you would need to leave it, as I accidentally discovered this option by storing my camera for a year (wanted to have it repaired for a similar lock-up problem, which turned out to not be necessary after all ^_^). You will know the memory was cleared when you have to re-select language and date+time when starting it again.
I had the same problem with my iPhone 15 Pro. I simply deleted the previous connection in the app and recreated it. Everything worked.
Hello 10 years later... So what I did is I cut the inner structure so it doesn't have to fit inside the body. Then I used a double sided tape. Poor camera even doesn't have a working screen. Or is it happy because I still care about it?
