Hello everyone!  Happy Holidays!  I hope everyone is doing good, staying safe and enjoying these times as best and safely as possible.
I am curious to know if anyone has had any issues with the XT-4 overheating?  Mine overheats when I shoot at 4K.   I am unable to shoot over 20 minutes continuous before giving the camera time to cool off.
Is there a fix for this?  I have already installed all the available firmware updates and I am still getting the overheating issue.
Let me know,
Thank you
