Recently started to explore Pergear 35mm F1.2 lens on Fuji X. It's quite an interesting glass, and I'm going to discover more details about the internals soon by disassembling it.
For now here's the initial review article of Pergear 35mm F1.2 on Fuji X-E2s camera. I'll keep updating it with more pictures and discoveries.
Edited by yukosteel
Few pictures from Pergear 35mm F1.2 with Fujifilm X-E2s:
Article on modifying aperture ring of Pergear 35mm F1.2 to introduce click-stops.
