Hi,
I have a problem with my q menu. I have attached a picture. As I shift  through the different possibilities, the highlighted item appears in words - in this case, noise reduction. However, I cannot revert to the normal situation where the menu displays C1. I have gone out the q menu many times and turned off and on the camera but nothing helps. Any advice would be appreciated. Thanks,
Steve
