"Hawk-mountain-cave", is a name of a cave where I live...
Visited  an old  mine yesterday evening, July 31 2020, named "Hawk-mountain-cave", that is from beginning of 1700s so it is about 300 years old.
They mined iron horizontally in to the mountain top. The horizontal mine was active until middle of 1800s.
Just trying to learn how to use my new Fujifilm X-T4 camera.
/Bo
Edited by bem
The larger right cave, there is also a smaller left cave.
There is a place to have barbecue in the large cave :)
Edited by bem
The smaller left cave.
