I have a focus problem with my XF 10-24mm lens.
If I manually focus, using the hyper-focal distance, at 10mm and f11, the resulting image is only sharp in the centre. If I set the focus close to infinity, the whole image is sharp. In both cases the distance indicator shows front to back sharpness. I have to focus very carefully to get a sharp result. This is my second lens which is better than the first one I had but at 10mm I should be able to get a sharp result no matter what distance is selected.
Has anyone the same problems?
