Hi!
I just bought the KIWI Pentax K to Fuji X Lens Mount Adapter (model AP205). The Adapter has electronic aperture control. I try to use the newer Pentax auto aperture (DA and Limited) lenses.
How can I control the aperture from the XT4? The main screen shows the aperture as F0 and aperture can´t be changed with any command dial.
The link to the adapters Ebay page: https://www.ebay.com/itm/KIWI-PENTAX-K-PK-LENS-TO-FUJIFILM-FUJI-X-PRO1-X-E1-X-M1-FX-CAMERA-MOUNT-ADAPTER/312124039509?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Best regards, Eetu Lehmusvaara
