Hello, I recently bought a Fuji XH1 brand new from eBay for a great deal but after spending 3 hours or more going through the menus and setting it up the way I like and putting it away in my closet. 3 days later I go and turn it on and the camera has reset itself to it's factory settings... I once again went through the setup and after a few days the system reset again.... Has anyone else had this issue and how did you fix it?
