I wrote in support, but they did not answer me.
In many cameras, even the lower price segment, this function is. Its implementation is inexpensive for developers. But as I understand it, not all Fuji cameras have it.
Where can I get information about models with pixel mapping?
Edited by NikVladi
On their web-site, Fujifilm gives easy access to their manuals for each camera. For the camera body you are interested in, look in the section called The Shooting Menu to see if pixel mapping is supported. Quite a few bodies do support that.
