Raf vs Jpegs
Hey - sorry for the base question. I shoot jpeg and raw, I shot in bright sun yesterday and the two images came out looking crazy different, like they have different profiles applied to them. The raw was waaaay more contrasty. If anything I’d expect the raf to be more desaturated before being worked on.
have I done something crazy?
Welcome!
Which Film Simulation profile do you have your camera set up for your jpg images?
Bright sunshine can make for some toasty contrasty images which is what you are seeing reflected in the raw files. If you are using Provia or one like it for your jpgs, then you are seeing the camera doing backflips to tone things down, Provia is a fairly muted film compared to Classic Chrome.
