Hello Everyone,
Just quick question - is it normal?
After making shot X-T30 screen (same makes viewfinder) is flickering for a while, please find attached video.
I was testing different body (also x-t30) with same lens and settings but on different light and I am almost sure that there was nothing like this.
It is fine, when I change Shutter to manual, but on Auto it is doing something after every shot. I am not sure, if this body is broken or is it normal.
And second thing, this is probably normal (?) - screen goes just after few seconds to some mode, where view refresh rate is extremely slow - second movie attached.
Edited by zakupy
added movie and comment
Maybe here is more visible:
Flashes after every single shot, screen is blinking:
https://www.dropbox.com/s/l5kk5565tk61gx0/flashes on screen_xs.mp4?dl=0
Slowdown after few seconds of not using camera:
https://www.dropbox.com/s/cwegea0tribvks4/stroboscop_xs.mp4?dl=0
Anyone? Is it normal or should I return camera and get new one. This is a gift for someone so I need to hurry to be sure that I have fine camera or it needs replacement:)
