Apparently we just got a “ Classified” section and it is operating already  :) .
So, after a post by the Admin who, I suppose, created that section, there is already the first ad already there.
It appears to operate very easily
http://www.fuji-x-forum.com/index.php?app=classifieds&module=listing&do=cat
There are 3 main sections for camera lenses and accessories
We can attach pictures (very important!)
Decide on the currency ( three options € $ £)
An whether is a Wanted or For sale advert.
There are no restrictions that I can see for placing an ad ( length of membership or number of posts).
So, I suppose this answers your question.
Good luck to all with buying and selling.
