Geekster 35mm f/1.1 for Fujifilm X
Fuji X Rumors
Geekster announced their Geekster 35mm f/1.1 lens for Fujifilm X. the brightest 35 geekster 7 Lens Formulas In 6 groups F-stop. Click. the fangs can be upside down. High Quality Metal Bodysuit You can order it at their facebook shop.…
The post Geekster 35mm f/1.1 for Fujifilm X appeared first on Fuji Rumors.
Full Article on Fuji Rumors
    • Hi all, I notice that there are some focusing sound on my XF33 despite it being said as completely silent in many review. The focusing sound is kind of like stepping motor sound, and it only appears when I’m shooting photo. I try shooting near and far away and there is sound. However, it is completely silence when I shoot videos. Is it normal or do I need to change some of my setting? Or am I just getting a not too good copy haha. please assist me with the matter guys! Thanks!
