Hello,
after having a camera since December 2018, I suddenly cannot access ISO values lower than 400.
I haven't done any settings changes, just noticed that suddenly the lowest ISO value I can pick is 400 (100 and above, up to 400 are grayed out).
Thanks in advance for any hint.
Edited by Tonino
to provide info about the camera type
