There are two irritating bugs that I have noticed with the X100S and the exposure compensation dial.
1. I focus, tap the AF-Lock button to lock focus, and re-compose. I turn the exposure compensation dial to adjust the exposure and…….. nothing happens. The dial doesn’t function whilst focus is locked. I have to unlock focus, adjust exposure compensation and lock focus again.
2. I’m in manual mode at say, f8, 1/250, Auto ISO. I half press the shutter and the camera selects ISO 800. I adjust the exposure compensation dial to open up by 2/3 of a stop. I half press the shutter again and the camera selects…….. ISO 800. Once again the exposure compensation dial fails to function.
Does the X100T have these flaws or did Fuji fix them?
Fixes to both bugs might be worth the upgrade but not just for one.
I wonder why they left the first one in there? Leaving it in suggests that they regard it as a feature rather than a bug, but I can't think of a good reason for it to function like that. Definitely seems like a bug to me.
They fixed both issues.
