Hi there,
I have been in Yosemite National Park 2 weeks ago with my X-Pro1 and 23 mm and 18-55 kit lens. My prefered lense was after a few shots already the 23 mm prime - sharpness is just perfect!
More pictures can be found at -> http://bit.ly/meinyosemite .
Cheers, Seb
