Fujifilm GFX100 Customer Reviews: “100 MP is Phenomenal, if You can Afford it, Get it”
I get the error as well with the Nisi all in one kit on my x100vi. It’s because the lens touches the built in UV filter when focusing at minimum distance. I love the kit, but it’s disappointing because it was quite expensive and I don’t want to use it and damage the camera
I have been using a TT Artisan 27mm 2.8 AF Lens for the past 18 months and it works fine. I tried three different fuji lens and the all caused the blinking/Lens error problem. I have tried everything that was recommended to remedy the problem but have had no luck what so ever. Is this a firmware issue or a mechanical problem? If mechanical why would only one lens work and not the others? I hope someone comes up with a different solution that I have not tired before sending it off to Fuji. Thanks in advance! Cheers, BR
X Raw studio initially recognises my x-e4. Then it doesn't. It then starts searching for it. Sometimes it finds it and I can use the app for a few minutes. THen the search process starts all over again. Most of the time not finding the camera. I then need to remove the battery in order to stop the green light flashing. I tried different cables and ports but the result is always the same. I have installed the most recent update as well 1.220
