I took my Fujis to my daughter's graduation.
Took my X100s, plus my X-T1 with two lenses, the 16mm f1.4 and the 56mm f1.2.
Looking back on the images I took, most of my favourites were taken with the 16mm. The combination of wide angle and wide aperture allows you to isolate the subject, while at the same time allowing you to keep in plenty of context to tell the story of what's going on.
82e230cc5c0cca1e5b271f39a866d33a.jpg58ce6c881d0885f1db6a313f38a3c53a.jpg53f25e47a75cc6edbf8fb7362b5e5867.jpg
Here's one taken with the 56.
It has a different sort of feel to it. Like the camera's bringing everything in to the subject, where it the others it's opening out from the subject.
