Ok, I just upgraded from an XT-1 to the XH-1. Wow!
Anyway, I have noticed that the screen will go very bright (flair) when you first turn the camera on and also when you review a picture and transition back to shooting mode. It's brief but can be distracting.  Is this normal sensor behavior or a setting that needs to be adjusted?
Thanks
Dan
