Hey Fuji Fans,
I have recently bought an XT-3 (which is great). I use it a lot for work where I take a lot of photos.
I use the camera remote app to get the photos on my phone quickly. It worked quite well, but recently (I think since the recent firmware update) it will only send 3 max, photos to my phone and then say 'task complete' even if I'm sending 40+ pics. I often send a lot of photos, so I have to send 40, it'll send 3, then I have to switch the camera on and off, it'll send 3 more repeat, repeat, repeat.
Anyone else run into this error. I know the app is pretty bad anyway, but it used to send 40-50 photos no problem.
Thanks
James
