Does this look like a dead pixel?
I noticed a blue colored pixel in today's photos, from yesterday's shoot, there was nothing visible.  So i did a dark series of exposures, with no lens, cap on and varying ISO/shutter speeds
Magnified to 11:1 in Lightroom
