Hi all,
I recently acquired a fringer EF-FX adapter and bought Canon 10 to 18 wide angle; tested and noticed focus speed was good  I have read reviews that Canon 100 to 400 II is equally if not sharper than some primes like 400 F5.6 and better than Fuji 100 to 400. Price of both the lenses are almost same.
I would appreciate your experience using Canon 100 to 400 II with Fuji. Thanks in Advance.
Regards
